h&m racing design ford raptor long travel kit (clean post)
C
canamds450
Why's the door off??
Dont know, the guy did it without my concern. Door laying around and few minutes after i was there showing a video of the process without removing the door. Rained so hard, i felt so bad with for my truck being like that.
C
canamds450
Whys the rum gone?
Hey anyway, i m trying to keep my post clean.
Any good comment will be accepted.
I will disregard any type of unrelated comments within this thread.
C
canamds450
http://youtu.be/hBZviLs6DwA
A lite test of the long travel kit
Need some final touches at the fenders ant suspension tuning
Do i need to install deavers +3 at the rear or do i need to drop the fron end? With the preload ring
https://vimeo.com/109650842
ntm
Alberta, Canada
You want 2/3 of up travel from ride height, and 1/3 droop travel. You can use that rule of thumb to establish a ride height in the front and back.
C
canamds450
Yes, Thanks for the info.
The way you see it, what would you do? Lower the front end or rise the rear?
C
canamds450
I'd set the front at 60/40, and the rear at 60/40. Bust out the tape measure and see where you're at.
I only have a 1/4" of preload ring on coilover, it will not drop that much
E300-195-800 is the spring rate of my shocka d 7 1/4" top spring.
The welder located the coilover 1/4" lower than bypass, he did not level lower shock body
ntm
Alberta, Canada
King makes a 3x18x750 spring if you find it necessary to lower the front.
My brenthel kit uses a 3x18x700, with a 3x4x500 tender spring, for example.
