Gen3 Losing Brakes
SurfRaptor
Newport Beach CA
Check your fluid and trace the lines from the master cylinder all the way back to each wheel. If your stepping on the brake pedal that hard you will see fluid for sure. Is the master cylinder full of fluid also?
I thought you had a Gen 2 so something to keep in mind here as there is a slight variation to the Gen 3 I think.
Keep me updated if you need parts. I’m heading down 1/4 of the way on Friday.
tabvette
Canandaigua, New York
Im losing all braking power on the truck. Truck has 2000 miles on it.
Unfortunately im down in Mex right now with very limited options here.
I had to finish the last stretch for an hour with no Brakes.
Ive disconnected the Neg Battery Cable to reset the computer a few times. That has done the trick. But keeps coming back and have almost lost the truck a few times.
Brakes are gone again from 5 min to 20 min....
Anyone experience this and what did Ford tell you?
Are you alive?? Did you make it back?? We need an update??
@KentSD is a busy dude, when he’s not baja-ing to everyone’s envy.
I’m sure he’s not making $hit up.
Gashawg
I’m not sure about him but I just experienced the same thing. 2022 37PP. Brake failure. I swapped the rear anti skid/speed sensor harness due to a hard fail. The brake issue seemed to subside. I just did a track event and the pedal went to the floor, missed a turn, through a small ditch and turned around. 40k miles on it, no fluid leaks, no codes. If it happens on the highway this will be bad.
