GEN3 Forscan
ekav555
philadelphia
Negative. "X" is where you do NOT change the value.
Normally the shown value, 1,3,F, whatever - is the value that will set the option.
We are saying the same thing. I just worded it horribly. So where there is an “-“ in Forescan document you put “-“ to replace the value that’s already there?
swoop1156
USA
No, I never understood why they did that. Everything stays, X, -. Just replace the value that changes the function
Littlefx4
Absolutely DO NOT change those values (“- -“). As @Antho explained it to me, those last two values are Sum values that will automatically change based upon the correct values that you do change. Leave the dashes “-“ alone!
Littlefx4
Using your example from post 619…Eg: 7D0-01-04 xxxx FDxx xx--
You would change “FD“ to the new value, let’s say A3, and leave the rest alone. The “- -“ at the end will automatically Sum based upon the change you’ve just made.
ekav555
philadelphia
Thank you and to the rest. Not sure why that’s not in the google drive but I’m sure it’s somewhere else possibly. Thanks guys.
Antho
Forscan made it easy for us and it auto Calculates the checksum. If you didn’t know those last 2 values where an auto check sum it would confuse you as it would keep changing to the proper checksum. Now, if forscan didn’t have the auto checksum it would be a real PITA making changes then calculating the sum. LOL
JayRods
Manteca Ca
Not sure where you're getting lost. Choose the country and language then enter your info on this page and hit submit. Will then spit out a list of all the original codes.
Hey Thanks again for that link.
I was just comparing that factory list, to the Forscan modification list, and noticed that the codes for my truck all match the current changed codes. The few that I've checked are the changed codes. Odd !!!
So I'm still looking for someone to give me the FACTORY Fake Engine Sound code. Please !!!
swoop1156
USA
Are these the areas in which need to be changed? Did a quick search and this is what I found. If so, my factory codes are in bold from a 2022 801A.
ACM 727-01-01 xxxx x0xx xxxx 302B 14FD 10AC
DSP 783-01-01 Exxx xxxx F40D 800D
RGVRaptor
South Texas
IDK if this has been covered or not.... But all I want to do is adjust tire size since I switched to 37s and reset the live valve shocks to zero since putting lift....
Is this possible with the iPhone app? I have zero desire to buy a PC laptop just to make those 2 changes and stash it in a closet.
Or.... If anyone in the Rio Grande Valley happens to see this and has Forscan... I will pay you for the adjustments. $$$
