GEN3 Forscan
Littlefx4
Is this possible with the iPhone app? I have zero desire to buy a PC laptop just to make those 2 changes and stash it in a closet.
It's very possible w/ iPhone app provided you have this attachment...no PC laptop needed.
JayRods
Manteca Ca
I just went for a drive and glare free sure works good. You don’t really notice the switch from high to low now.
does your dash still show the Blue auto high beam symbol or is it something different ?
I did all the changes but mine still looks the same :/ Not sure if it works or not.
swoop1156
USA
High beams is Blue. Auto high beams is white. Glare free is Green.
JayRods
Manteca Ca
Now you have me going...
I have high beam or no high beam. I no longer have the Auto HB symbol.
I do have Glare Free lighting on my sync screen
swoop1156
USA
That's wild. You should have three "instances" when you use the stalk. One is auto (granted you have your headlight set to automatic via the knob). Must be set to Auto or none of this works.
You have auto, which is always a white signifier for auto high beams. When glare free is enabled, that will look identical, except it's green. You can force high beams by pressing the stalk forward.
Forward again goes low beams. Forward again should revert back to auto (green or white)
You want Green for glare free.
JayRods
Manteca Ca
I'm not getting any of that :rolleyes: I set up all of those codes and double checked them.
JayRods
Manteca Ca
It’s a green high beam with an “A” in it.
I messed with it again
Now I have a the Blue high bean, the Green "A", but no White "A" I've checked everything 3 times.
