GEN3 Forscan
Chuckaroo91
Boise, ID
Well that sucks... I'll have to go back and read what your changes were and see if I can help any. Perhaps go back to factory/restore your saved ABD module data, clear DTC, scan, and then see?
All I can think of at the second is redoing what you did in order and see if it continues.
Bambi lights, remove double honk, turn up DRLs and adjust for 37's. Nothing too crazy.
Is there a way to mass upload the factory as-built data? Or its a manual entry for everything? (I'll have to look if I saved down the first time I plugged in).
EDIT: Looks like I have two files. Bdy_CM and PCM data in ABT format from when I first got the truck
10SpdsOfFury
Jacksonville FL
I decided to try to get Glare free to work and think I got it, menu says glare free now and I am not getting any errors. Question I have is in the Forscan menu where you can just enable and disable the adaptive lights shows disabled, does that have anything to do with the auto high beam or Glare Free?
swoop1156
USA
I've done all that, minus the 37 adjustment, though I've also done the glare-free change.
To my limited knowledge, you must go one by one and restore the ABD values for your entries if you haven't saved them. I screwed up and didn't save mine as built once and simply opened the file as downloaded from Ford, in Notepad, searched for the line, and then went from there with the values. Please PM me if you need help with that - I'll do what I can.
Oof, that's a really loaded question. Simply, no. It is not a one and done option. You MUST go through all the individual modules and make the appropriate settings.
FORSCAN engineers and people behind the scenes attempt to make the best description of what an option does for those of us that don't want to get into the actual configuration (ABD) and go with simple text explanation.
That's absolutely not how it works, plain and simple.
My Mustang was my first foray into FORSCAN and thankfully everything I wanted to change was simple and was also offered by the text description they had.
I read a lot more into enabling glare-free (and not ashamed to say I experimented on an overnight test drive...) before I did it to my own truck. Is what it is.
Lemme know if I can help.
JayRods
Manteca Ca
No
Not sure where you're getting lost. Choose the country and language then enter your info on this page and hit submit. Will then spit out a list of all the original codes.
Hey thanks, The correct page came up when I clicked your link, I didn't get that the first time.
Thanks again
Chuckaroo91
Boise, ID
I havent noticed this before. Should I be concerned about DTC codes? These are currently showing when I plug in.
PCM: Code: P160A - Control Module Vehicle Options Reconfiguration Error
TRM: Code: U0140 - Lost Communication With Body Control Module
ABS: Code: U0253 - Lost Communication With Accessory Protocol Interface Module
TCU: Code: U0146 - Lost Communication With Serial Data Gateway 'A'
SODC: Code: P160A - Control Module Vehicle Options Reconfiguration Error
Reverted back to factory values and a PCM relearn did the trick for those that encounter this issue.
ekav555
philadelphia
Im having brain fog! It’s been a few months since I did Forescan. Obviously replace the values where x is not but what about the “-“
Eg: 7D0-01-04 xxxx FDxx xx--
swoop1156
USA
Negative. "X" is where you do NOT change the value.
Normally the shown value, 1,3,F, whatever - is the value that will set the option.
96,206
60,054
stephan1075
