GEN3 Forscan
boredm
MS
tried searching but came up empty.....are there any changes that can be made via forscan to the hud....be nice if there was high beam indicator for one
BigVol
KY
New member here. Read a lot the last couple of days on how to do the Glare free edit (worked like a charm), But boy it gets a lil confusing.
Some of the post folks say they have issues with the 3rd brake light and license light staying on when they do the DRL change. So I’ve been hesitant to do the DRL change.
I’ve been thru the spreadsheet and have the latest update for Forscan.
So my question is, and I know it’s been beaten to death lol, but what values change the DRLs to JUST have Fender Marker, Grille and Headight surround. Is there a value I have to disable to keep the license light “factory”?
All I want to change is to have ALL Amber surround, marker and grille lights.
I think I know how to reduce flicker % values are 4B= 75% and 32= 50%.
So will somebody reply with just those 3 values for all Amber up front and if I need to change anything to do with rear marker or license lights (disable?)
Much Appreciated.
Oh and mine is a ‘22
CT
Has anyone had any luck with this disabling the recirculation from turning off automatically?
I've seen many references about this, but my "OEM" value is not A, it's 7. I've also seen people post that this did not work for them.
HVAC
733-01-07 xxxx x8xx xx (If OEM is A)
This disables the “Enhanced Windshield Anti Fogging Strategy” which is the primary cause of the recirculation turning off.
Nyseguy
Long time Raptor owner but new to FORScan. I got my 2025 early January and have been trying to use FORScan. I can not connect to the vehicle. I am getting the error that the newer vehicle can not be connected until the next release unless I have a paid license, but the way it reads FORScan is no longer selling paid licenses. Am I just stuck waiting for the next release date or is there anything I can do?
Edit: found the error message
Therock88
Office Chair
Yeah ...Looks like Putin F'd it up for them to get paid. Looks like they are working on finding another payment solution. See their note directly below
From Forscan:
December 18, 2024 - Suspending Windows and Android FORScan License sales
We were informed by our payment processor, PayPro Global, that they will be unable to send payments to Russian banks anymore due to recent changes in global sanctions against Russia. As a result, we have to suspend sales of FORScan licenses for Windows and Android. We will try to find new payment methods and routes.
We haven't received a similar notification from Apple yet, so thus far FORScan Lite for iOS will remain available in Apple App Store.
HTXRapt0r
Houston, Texas
I downloaded and installed the trial extended license but received an error message when trying to connect to my 25 Raptor. I get this error message:
According to this thread (https://forscan.org/forum/viewtopic.php?f=5&t=28216), this error only occurs on a tuned PCM but my truck is stock.
I emailed support so I'm waiting on their response.
Nyseguy, you could try the trial extended license and see if that works.
Nyseguy
I think we are in the same boat waiting for them to update the database for 2025s.
James628
In my reading and collection of data (all via this particular thread) I havent located a Module Descriptor for address listed along with the parameters/characters to edit for the desired result for a posted value edit. A couple were obvious given the first 3 characters of the address. The ones Im mentioning are the “lane change turn signal count” and the “offroad IOD/IOD#2”. Lane change were obvious to be of the SCCM. But these offroad IOD changes…… were not detailed. Unless, of course, I just went right by them, way more than once. Should I be able to interpret their respective module via the address?
7D0-01-03
7D0-01-04
Ah. I suppose so. 7D0 indicates the APIM. Supposed I talked/typed my way to realizing it.
Thanks anyway.
Also, this FORScan availability hangup is a bummer/inconvenience.
2022, Agate Blk Met, 801A
beo_tom
USA
Hello all! I'm from the f150 Tremor forum, and I just swiped some OEM raptor headlights for the gen 3 raptor to swap in. If someone would be so kind, I'd like to see the base values for the BCM lines that pertain to the headlights. I know of only one line for sure that needs to change and it's DRL as turn (726-38-02 I think) thanks in advance for whatever kind soul is out there
