GEN3 Forscan
HORN HIGH ACES
Colorado
It’s in the settings for one of the modules within forscan. I found it after browsing
I haven't located it so any assistance would greatly appreciated.
EDIT: Found it in BCM.
726-10-01xxxxxxxx**--PlacardFront_Cfg (PFC) • Psi = Hex2Dec(**) • Range: 0 - 255
726-10-02**xxxxxxxx--PlacardRear_Cfg (PRC) • Psi = Hex2Dec(**) • Range: 0 - 255
tm965
NOVA
there's also the ability to do it in the simpler menu--no need to mess with the as built values
northlaker
DFW
How do you read this or rather what do change to get the sensitivity reduced? I'm not smart enough for that formula speak on the right :)
HORN HIGH ACES
Colorado
You have to select a new threshold value. Default is 38 psi which equals 26 in hex.
Go into your BCM as-built and the ** values should be at 26.
If you want to adjust the threshold to 35 psi for example, you would update the ** values to 23.
You can also select different threshold values for the front and rear if desired.
northlaker
DFW
Hero. Thank you!
figure1a
San Diego
Mine turns on every time I start the truck. I have to manually go in and shut it off(2023).
Looking for this too. The fans on the Pro Power are so loud so I have to shut down the Pro Power each time I start up but then it still takes another minute or so before they shut down. It would be nice if Pro Power was off as a default and then I turn it on when I need it (which isn't very often).
Jred2255
MN
Has anyone used Forscan on their 2025?
I have a new license and the latest version, but it says it does not recognize my vehicle when I plug it it.
RaptorFun
Northeast Wisconsin
Had the same thing happen to me after I took delivery of my MY24 Raptor last April. I contacted the FORScan development team and provided them with the VIN. They in turn provided me with a link to download a flavor of FORScan that would work on my truck. I suspect I will need to retrace my steps when I take delivery of my MY25 in a few weeks. Hope this helps.
Jred2255
MN
Good info, thank you. I saw a sticky on their forum that they are continuously adding VINs each day. I'll reach out if it doesn't work in the next couple weeks.
