GEN3 Forscan
JayRods
Manteca Ca
Need Help.. I have a 2023 Raptor 37
Can someone please give me the factory setting for the fake engine noise ? Like a dummy I didn't save it. I want to turn it back on a see if I can notice a difference in road and tire noise. I think it was also doing the noise canceling inside the cab.
I want it back
The code to disable it is,
Disable Fake Engine NoiseACM727-01-01xxxxxxxx0x--
Chuckaroo91
Boise, ID
I havent noticed this before. Should I be concerned about DTC codes? These are currently showing when I plug in.
PCM: Code: P160A - Control Module Vehicle Options Reconfiguration Error
TRM: Code: U0140 - Lost Communication With Body Control Module
ABS: Code: U0253 - Lost Communication With Accessory Protocol Interface Module
TCU: Code: U0146 - Lost Communication With Serial Data Gateway 'A'
SODC: Code: P160A - Control Module Vehicle Options Reconfiguration Error
I want it back
Use this to find defaults
JayRods
Manteca Ca
Thanks, I clicked on the link but couldn't figure out where to look from there.
Chuckaroo91
Boise, ID
Not sure where you're getting lost. Choose the country and language then enter your info on this page and hit submit. Will then spit out a list of all the original codes.
swoop1156
USA
Did you clear the DTCs and then rescan? Mine did that and I cleared it, scanned again, and everything was good to go. Same with my wife's Lincoln - had em, cleared, scanned, and all were gone.
Chuckaroo91
Boise, ID
You cleared by just using the "Reset DTC" option? EDIT: Just tried clearing them and they are sticking around.
swoop1156
USA
Well that sucks... I'll have to go back and read what your changes were and see if I can help any. Perhaps go back to factory/restore your saved ABD module data, clear DTC, scan, and then see?
All I can think of at the second is redoing what you did in order and see if it continues.
