Dalejbrass
without going through 80 pages of comments, is there a ford raptor master list. i found an F150 one, but was wondering if anyone made one for the raptor (mine is 2018)
thanks
Mjolnir
^^What he said^^
Anyone willing to point a couple noobs in the right direction vs reading 80 pages of threads?
Thanks in advance
xxaarraa
Southlake, TX
Obscure
Anyone mind telling me the values they have for IPC 720-01-01
I was getting errors when going to backup the As-Built and think I may have fatfingered one of the other "x" values when disabling the seatbelt reminder.
ogdobber
fwiw the seatbelt reminder can bo done easily without forscan. it is just a sequence of plugging and unplugging the seatbelt in a specific way/order
I have got to stick up for Ford and the Raptor here. Pre-Raptor I had a turbo outback, the seat belt chime was persistent, never going away. I hated that annoyance. I can remember 1 time when the Rap gave me static about the seat belt and it was because my wife was trying to reach into the back seat.
wreedsvt
Yuma, AZ
The obnoxious auto/start stop forced me to finally do this and I'm glad I did it. I did the auto/start stop disable, lincoln mirrors, double horn honk disable and seatbelt minders. The secure idle seems like it could cause problems if the battery is low in the FOB so I skipped it. Also I used the cheap $18 cable from amazon and it worked fine.
What problems can secure idle cause?
---------- Post added at 01:26 PM ---------- Previous post was at 01:17 PM ----------
When you disable the beltminder by doing the sequence in the book, will the value update to the disabled value if you scan your truck again with Forscan?
-Ryan-
___
I'm just speculating. I haven't heard of anyone having this issue but the way secure idle is described, it seems like if the battery in the FOB was low or out you could end up being stuck somewhere. I don't know if that's ever happened but it was reason enough for me personally to skip it.
Obscure
How long does it normally take you guys to save your as-built data for a module? Mine just sits at 0% every time I try to save it.
Would still greatly appreciate it if anyone could tell me the values they have for IPC 720-01-01
Everything seems fine on my 2018, but I just don't have the warm fuzzy that I didn't write a wrong value for it.
96,098
59,851
swhitt392
