Forscan changes - tweak your truck
av8roc
Can you forscan boys help out with an issue I'm having?
When remote starting my truck and climate control set to auto my steering wheel heats up but my seat heat does not. Only when I get in and press the engine start button do the seats begin to heat. I'm thinking that possibly a setting is off in the coding and maybe forscan can potentially fix?
Toadster
Folsom, CA
any way to modulate the electric fan temperature range control for the radiator and/or intercooler fans?
dewalt
What is value for tpms at 30 or 35 psi? Tks
You will have to get the ForScan program, an adapter to plug in to your OBDII port to connect the computer to the truck, and change address 726-40-01 to:
726-40-01 xxxx 2424 xxxx - 36 psi for front & rear (Those numbers are probably xxxx 2B2B xxxx now.)
Do not change the places marked "x."
Study this: https://docs.google.com/document/d/1...gF1wxIqxY/edit
as per rliles1 at f150
Livnitup
SoCal
726-40-01 xxxx 1E1E xxxx - 30 psi
726-40-01 xxxx 2323 xxxx - 35 psi
dewalt
Tks Should be able to set 35 and run 33 on the back in the winter. Summer running is 35 in the back
Mjolnir
Colleyville, Texas
without going through 80 pages of comments, is there a ford raptor master list. i found an F150 one, but was wondering if anyone made one for the raptor (mine is 2018)
thanks
Mjolnir
