Livnitup
SoCal
I've revised the following item on my BCM spreadsheet to include the bold notes below it:
726-26-01 **** xxxx xxxx - Ambient Light Sensor Type Cfg: 0=Slow_FNA, 1=Fast_Row
0=15 seconds delay turning on headlamps when dark, 1=2 seconds delay turning on headlamps when dark
I haven't looked to see what the Raptor default value is but some guys didn't like how the headlights would turn on so quickly the second they drove under some shade and they found this address/value to be associated with that delay.
mikeyj67
Default value is 1
Seven
Wow, nice find. That is a major pet peeve of mine, on how quick the interior dims after driving under a bridge. :biggrin:
I'll be making the change tomorrow.
Seven
Hmm, its been two months since I've touched Forscan and now after connecting, I get this message when reading the BCM module.
"Sorry, you need an Extended License to run this function"
Anyone know what this means? I thought you only needed extended licenses for special functions. Guess I'll need to go visit their forum and readup.
ok, guess the license is 2 months and that is probably the last time I used it. Guess I'll see how much to pay for the license since I find it handy. Thanks.
Gunnut
Cut Off, LA
Not sure if this is a Forscan issue or a fix. My cell phone is paired with my truck's radio. I can receive phone calls and hear my usual ring tone. But when someone texts me while I am in the truck my phone just vibrate with no text tone. This happens with anyone else?
It depends.
Your phone may be paired, but, it may not always be paired (enough) for texts. I have my phone set to flash, vibrate and chime. when paired, I usually see the flash, vibe and get the incoming text message prompt. The truck isn’t quiet about it though.
I really wish the text pairing wasn’t as fragile as it is. sometimes I forget to confirm it and miss the local traffic alerts.
when the texts aren’t piping through, I don’t remember if it chimes.
Nick@Apollo-Optics
I'll definitely be adding this one!
kromealt
Anyone have luck tweaking their Powerpoint outlet cutoff time with forscan? No matter what I set my outlet turns off immediately - even with battery monitor off.
726-39-01
xxaarraa
Southlake, TX
726-39-01
I remember trying to set it to 45 mins back when I first got the truck, and my experience then was the same as yours. It didn't work and would always cut right out.
