Ballistic
Oregon
What do you guys prefer the USB or Bluetooth for OBD2 port? Is the Bluetooth worth the extra 50 bucks over the USB cable?
Robtor310
Redondo Beach CA
Awesome
Auto Stop/Start -killed
DRLs on
Autofold - Lincoln
Global windows
Killed the double honk
No seatbelt nannys
No door open chime
Gauge temp #s
Quick boot
Secure idle
Panic alarm, 2 presses
Instead of the reverse mirror tilt I just programmed em to tilt on seat memory #3
Thanks for all the good info on here guys
Livnitup
SoCal
Here's a new find on # of turn signal flashes that I think some asked about:
SCCM
724-01-01 xxxx x*xx xx:
0,1,2,3=1 flash
4,5= 2 flashes
6,7= 3 flashes
8,9= 4 flashes
A,B= 5 flashes
C,D = 6 flashes
E,F= 7 flashes
The truck will add 2 flashes to any of the above values when a trailer is connected.
Jayrod
FL
Question everyone:
When I try to connect Forscan now it shows an error unable to identify vehicle. Bluetooth and everything is good to go. I have already used it so my truck is present in Forscan. Any sugggestions ?
Livnitup
SoCal
If you like your stereo buttons on the left side of steering wheel instead of the right this value will swap button functions from right bank to left bank:
SCCM 724-01-01 xxxx **** xx Cluster Crossover Cfg: 0=disable, 8=enable
Note: This is only for the Up,Down,Right,Left/Center buttons. Not the lower set for cruise control, voice commands, etc.
Jayrod
FL
SCCM 724-01-01xxxx*xxxxxCluster Crossover Cfg: 0=disable, 8=enable
Anything for my issue I posted?
