I'm using the OHP ELM adapter (USB not bluetooth) and FORScan is unable to connect to my truck in MS-CAN. FORSCan connects to the adapter but I get this error message below of it not being able to connect to the vehicle (ignore the first error at 13:10:52 as the adapter wasn't hooked up in the USB yet). When I switch to HS-CAN and hit reconnect, everything connects find but it disconnects if I switch back to MS-CAN. My first thought is the adapter may need an update but I haven't been able to find where/how that's possible.
Anyone have any ideas why the OHP ELM won't connect in MS-CAN to my Gen 2?
My only issue with this tool so far is the speedo recalculation. In the BCM module 726-12-01, if I change the second set of Hex to match tire size from 34.4 to 36.7, I get wrench icon in the dashboard.
I can go back to original Hex, no problem. I have the saved values and screenshot of original. Just wondering why I can't have my speedo correct without wrench icon specifying Code P160A - Control Module Vehicel Options Reconfiguration Error in TCM.
Perhaps I cant have the cake and eat it too.
install the drivers into the cpu from the website on the paper with the elm
Yeah make sure you have the correct driver installed and reboot computer. Your adapter switch should be in the HS-CAN position when you connect in FORScan and after it reads a few modules it should prompt you to flip the switch to MS-CAN to read the rest of the modules. If it isn't prompting you to flip the switch, click no when you connect and it brings up your previous VIN profile.
Hey Liv, sorry if this was asked before. But any codes to turn off the time limit for idling? Right now it seems to turn off automatically after 20 minutes I believe but would love to disable that and allow for longer idling time.
