dreys
San Diego, CA
Anyone knows what are the values for the following
- automatically unlock all doors when vehicle is shifted into park
- "dark mode" - do not turn on parking lights when doors are open
DINOZR
Southeast
Strange problem I noticed today after reverting from "DRLs- Parking Lights and Turns Only" to "DRL-Parking Lights Only (stock LEDs only"
Light switch is set to auto.
Ambient lighting is very dim. Truck probably thinks it's dark.
Got out of my truck and noticed the low beams are on while truck is in park.
Put truck in drive and engaged parking brake. Got out, and low beams are off (as they should be with the DRL mod).
Should the low beam be on in park when it's dark? I'm thinking not.
GunaRaptor
Alpena, WV
My buddy has a 19 limited f150. He put 35” tires on and we used forscan to set the speedo right and got a cel. Anyone know what’s up?
Livnitup
SoCal
Did you guys run the PCM relearn afterwards? First item in the programming screen is PCM relearn and that needs to be run after the tire size change. If you also see a TCM relearn listed then run that also.
MikeLadd
Dallas
Anyone have the 2022 Raptor Forscan Spreadsheet, not the enable/disable set but the actual numbers for the spreadsheet. Trying to turn off all the chimes on startup and door ajar.
Zeusmotorworks
Soooooo back before you had actual word descriptions I made changes to my 2020. Those changes were kept on paper... why cause I'm OLD. Of course lost the paper so dont have changes I made.
I never got what I wanted which was headlamp switch in auto, DLRs ambers less turns with NO headlights on. Also my turns are constant on. Anyone know how to unfuck me and get me where I want?
