DINOZR
Southeast
From a Forscan guru on a different forum -
https://www.motorcraftservice.com/AsBuilt - if you go to that link and it asks you what country you're in then set it at U.S. and then click the link above again and it'll be at a VIN entry field. The newer versions of FORScan have a button at the bottom in the (ASBUILT format) programming screens of the modules where you can automatically populate the fields with your asbuilt values if you want to completely restore.
Wow, that is a gold mine!
The address in question is
726-45-01
That link looks up my VIN and tells me the stock values are
0A00 1101 0190
Can anyone with a 2019 confirm that?
DINOZR
Southeast
I would check my backup file.
I suppose I haven't figured out how to load a module into Forscan and just peruse the values. I understand how to restore an entire module, but I've made so many changes to my BdyCM that I don't want to go that route.
Bitsniffer
Amarillo, Tx
Thank you Bitsniffer, I had looked through that post but wasn't sure I should use it for Raptor specific changes.
Yes. I usednon my 2016 502A and now my 2020 802A. @Livinitup has done more research on Forscan and these mods than anyone I know. He also will answer questions quickly.
RaptorFun
Northeast Wisconsin
726-45-01
0A00 1101 0190
726-45-01
0A00 1101 0190
I was doing some FORScan work this afternoon and thought I would scope this out on my 2020. The default value I had was:
0A00 1101 008F
I’m confident it’s the same value on your 2019.
Hope this helps!
