Woosta
Hey all, I successfully enabled bambi, removed double honk and seatbelt chime on my 2023 raptor but I am unable to get the windows to roll down with the remote. I used livinitup's spreadsheet for the 21-23 models. I replaced all the values with what's in there:
DDM740-06-02xxxxxxxx01--
PDM741-06-02xxxxxxxx01--
DDM740-06-0301xxxxxxxx--
PDM741-06-0301xxxxxxxx--
BCM726-11-02xx01xx01xx--
BCM726-22-01xxxxxxxx01--
BCM726-22-02xxxxxxxx01--
Any have the same issue?
Antho
I would try adding it to the APIM and making sure it shows enabled after adding it to the APIM.
7D0-09-01- xxxx xExx xx--'
Woosta
I tried that, and I'm getting an error. I reached out to support. Wondering if the values on the spreadsheet are incorrect.
[17:03:56.018] Gain security access failed - security key is wrong
[17:03:56.0941 Service procedure has been interrupted
Antho
@MachineGunStelly
When loading forscan are you using a saved profile? Try doing a new scan without using a saved profile.. If that doesnt work, You may have to send logs to Forscan.
Woosta
@MachineGunStelly
I reached out to their support, and it's an issue with the 2023 models that is being addressed in the next app update. For now have to use the beta version of the app to make changes to the APIM module. Idk if it will fix the window with the key fob issue but will report back so others looking in the future find the info. If anyone has successfully done this on a 2023 or 2022 let me know what steps you took.
JayRods
Manteca Ca
Did you turn it on in the main screen ?
Go to
*Vehicle
*Windows
* turn them both on.
I had the same issue, then one day I was sitting in a parking lot waiting for the Wife and was playing around in there and found it.
PupDawg
Cheyenne, WY
Has anyone found a way to get a new license key? I haven't been in forscan for awhile and just learned the forscan sites are blocked and I need to make a few changes on a new vehicle.
