Ford Performance Rear Diff cover
Todd Turbo S
Todd Turbo S
Nor Cal
you're lucky, do you know if they used AMSOIL? If not, and it were me, I'd use their lube, very easy to change too with your ford performance diff cover...
Ricoman
WASHINGTON STATE
Installed a Ford Performance Rear Diff cover. As others have said, great quality, more stout and more lube capacity. I did this at 390 miles and had no problem removing the OEM cover. The surface rust came off easily with green Scotch-Brite pad. I flushed the remaining oil with an extra quart if AMSOIL, just very **** retentive.
Took me 2 1/2 hours. Took advantage of the spear wheel being removed and cleaned it/coated with Nyalic.
The instructions call to torque the bolts to 25 lbs, but everything I read and videos said 14lbs, so I opted with 14lbs.
Any of you guys use the Motorcraft Diff. Oil...?? Decided to go with the Spicer Dana Cover,$116 @ RockAuto..they dont sell Amsoil but do have the Motorcraft,,,but it says:
Note: For a complete drain and refill, some limited-slip axles require addition of Friction Modifier, Part Number XL-3 meeting Ford specification EST-M2C118-A. Refer to Workshop Manual or Owner’s Guide.
Did any one add the Friction Modifier....??
FILRaptor
Glad you asked, I have same question.
TRMFAM
Bartlesville, OK
Friction modifier is for limited slip axles I believe all Raptors have the E-Locker and would not require the modifier.
Hagasan41
Florida
Great write up. Just got mine in the mail! Todd, how's the Nyalic holding up? I plan to do a little undercarriage detailing since I'll be under the truck and would like to coat it once done.
