Ford Performance Rear Diff cover
Todd Turbo S
Nor Cal
Installed a Ford Performance Rear Diff cover. As others have said, great quality, more stout and more lube capacity. I did this at 390 miles and had no problem removing the OEM cover. The surface rust came off easily with green Scotch-Brite pad. I flushed the remaining oil with an extra quart if AMSOIL, just very **** retentive.
Took me 2 1/2 hours. Took advantage of the spear wheel being removed and cleaned it/coated with Nyalic.
The instructions call to torque the bolts to 25 lbs, but everything I read and videos said 14lbs, so I opted with 14lbs.
Todd Turbo S
Todd Turbo S
Nor Cal
Nice job. I plan on doing this one day.
Cute blanket, Btw.
Thanks, it’s very simple, just watch the videos. I’m a novice and my only problem, was, I didn’t check my torque wrench before I started and had to scramble to borrow my buddies as mine didn’t go to 11 and 14. Yeah, that is my sons first big boy bed set (6 years old, he’s now 28), comes in handy...
KCRaptor643
Tacoma, WA
Thinking about replacing it when weather gets better, is it straight forward, no issue/challenge, replacement???
Mark McAwesome
Iowa
Off topic but where did you get the exhaust wraps from? On topic, did you use the stock bolts that came with or get different bolts?
ezndo
FL
One more off topic question....that looks like a Stainless Works exhaust, does it rub/touch your spare tire at all? Mine does...
93,363
56,644
LDMiles
