Incorrect..
Ford has already been doing this for a few years now. My 2015 explorer sport temporarily switches to manual when a paddle is pulled and will automatically switch back if no further inputs are received. The f150 operations are different because, IT'S A TRUCK. Designed to do TRUCK STUFF. Locking gears out is a wonderful feature for towing and off road use... u know TRUCK STUFF. They designed the system appropriate to the design use of said system. And I for one think they got it right. Then again I don't pretend my truck is a sports car either. If there was anything at all I can find a problem with first on my list would be the fact that paddle shifters are attached to the wheel and not the column (all Ford's) are this way and I don't care for it.
The way Ford integrated the paddle shifters on the Gen 2 in regular drive mode is asinine. I understand that if you're in 'M' for manual it should react to whatever up or down shift you select however in 'D' Drive mode it should work like my wife's Infinity works. If I'm cruising in Drive and I hit '-' it should drop a gear, plain and simple, however it doesn't. Unless you're cruising in the top gear it basically drops the upper limit of the available gears down a notch. So if you're in traffic and your loping along in say 7th and have an opportunity to kick it in the butt and get around something you'll have to hit '-' down shift 4 times before you get a down-shift reaction. And when you're done it'll be stuck with that 6th gear upper range until you upshift.
While in drive it 'should' drop a gear regardless of what gear you're in when you hit a single downshift, and since it's in drive it should upshift whenever it's appropriate again. No muss no fuss.
As it works now it's pointless.
They’re a bit laggy in my experience.
Engage Sport mode, then pull the shifter into manual and use the paddles. They are much more responsive in this mode. Shifts are definitely quicker.
Really!? That's good to know. FWIW I didn't have a problem with response time in Baja mode, and the engine braking was helpful (well, my wife didn't think so, she got seat belt bruises from it)
Careful with Baja mode because it engages 4H and the diff lock. Don't use either on pavement.
