WhatExit?
FYI: Ford Raptor Transmission per the Raptor Supplement
Link: http://www.fordservicecontent.com/F...pplement-version-1_su_EN-US-EN-US_10_2016.pdf pages 9 & 10
Understanding your SelectShift™
Automatic Transmission (If Equipped)
Your vehicle is equipped with a SelectShift
automatic transmission gearshift lever and
steering wheel mounted shifter paddles.
The buttons on the gearshift lever and the
shifter paddles serve the same functions.
The SelectShift Automatic transmission
gives you the ability to change gears up or
down (without a clutch) as desired.
In order to prevent the engine from running
at too low an RPM, which may cause it to
stall, SelectShift still automatically makes
some downshifts if it has determined that
you have not downshifted in time.
Although SelectShift will make some
downshifts for you, it still allows you to
downshift at any time as long as the
SelectShift determines that damage will
not be caused to the engine from
over-revving.
SelectShift will not automatically upshift,
even if the engine is approaching the RPM
limit. It must be shifted manually by
pressing the + button or paddle.
Note: Engine damage may occur if you
maintain excessive engine revving without
shifting.
feature has two modes: PRS and M mode.
Manual (M)
Moving the gearshift lever to the manual
(M) position allows you to manually select
the gear you desire. Only the current gear
will display. Use the buttons on the
gearshift lever or steering wheel to
manually select gears.
Press the + button
or paddle to upshift or the – button or
paddle to downshift. Return the
transmission to a different gearshift
position to deactivate manual control.
Progressive Range Selection
Progressive Range Selection gives you the
ability to lockout gears from the automatic
shifting range. This may provide you with
an improved driving experience (for
example, in slippery conditions or when
experiencing a steep grade).
With the transmission in drive (D), press
the – button or paddle to active PRS. The
available and selected gears are indicated
on the instrument cluster.
All available gears display with the current
gear indicated. Press the – button or
paddle again to lock out gears beginning
with the highest gear. For example, press
the – button or paddle twice to lock out
10th and 9th gears. Only the available
gears display and the transmission
automatically shifts between the available
gears. Press the + button or paddle to
unlock gears to allow the transmission to
shift to higher gears. The transmission
shifts automatically within the gear range
you select.
over-revving.
shifting.
Manual (M)
Press the + button
you select.
