RatedSVT
Some good ideas in here. I was wondering how I could add more switches as well.
Yes sir...Scored from E-Bay...
I had my daughter make up some templets. Then just cut a hole in the side paying attention to the shifter behind it so there was no interference.
She made one for my E-flasher assemble also...I moved that down to..
[/IMG]![]()
I actully got a little crazy with the file when I was finishing off the hole. I didn't realize there was no lip on this side of the plate...
So little tape and some black painters caulk and I was good to go...
You can also buy the factory plug from Ford...I have the Raptor wiring book so I was able to locate all the wires for the plug function..
If anyone needs a copy let me know and i'll shoot you one..
I couldn't read a schematic if my life depended on it. Where do you hook each one of those wires?? I assume the plug goes into the upfitter panel, just like the factory one, but that mess of wires has me confused.
To be honest..If you have no idea what your doing you may want to get someone involved that does...You could do damage if you start poking around with wires under your dash..
This is a quick picture of my extra switches between the upfitter switches and the shifter.
Sent from my DROID4 using Tapatalk 2
