Extra Aux Switches Anyone??
iSurvive
iSurvive
Highlands Ranch, CO
OK guys, thanks! I'm going to do the tinting AND the fuse block panel. I looked for something like this at some auto parts stores, but had no luck. Now I know where to buy one!!
My son took this picture at TRR during the Exotic Animal Run, not sure what this driver was thinking!! Looks like something you'd see in some third world country - too many people, chickens, suitcases, or maybe AK-47s chanting some anti-American slurs. Forgot to mention alcoholic beverages!
:lol:
wiz1500
I put a second set in on the side of my console.
They are for my rear camera by-pass low amps no relay..
Trans cooler fan, 30 amp relayed.
And rear LED dust light no relay.
with one left for the future.
The Illumination LED's in them are changed to red like the rest of my dash and are wired in to the dimmer...
"Factory" look and function..
wiz1500
Are those another set of OEM upfitter switches?
Yes sir...Scored from E-Bay...
I had my daughter make up some templets. Then just cut a hole in the side paying attention to the shifter behind it so there was no interference.
She made one for my E-flasher assemble also...I moved that down to..
[/IMG]
I actully got a little crazy with the file when I was finishing off the hole. I didn't realize there was no lip on this side of the plate...
So little tape and some black painters caulk and I was good to go...
You can also buy the factory plug from Ford...I have the Raptor wiring book so I was able to locate all the wires for the plug function..
If anyone needs a copy let me know and i'll shoot you one..
RangerRob
Ramona, CA
That looks awesome. Thats where I was thinking of putting more switches. Hope I can find a factory switch panel on ebay.
-Rob
wiz1500
-Rob
It was last year when I did this but if memory serves me right the Up fitter from the F250 is the same. It dosn't have to be for a Raptor this will help broaden your search..
Looks great. Can you send me a copy of the wiring guide? Please and Thank You.
[email protected]
This is a copy of the of the factory harness colors..The plug from Ford will be all black but this tells us that your connector number is C3389 so you can get that ordered..
I will have to scan and up load the pin chart for ya as I just copied it when I used it with out saving..:thumbsdown:
I'v only been awake for 5 min. so let me get me eye's open..lolol..
As a side note.. When you guy's go to do this there will be very slight interference with the shiftier behind the switches.. You will have to trim the plastic sliding piece that is connected to the lever...Just trim the very end off so it doesn't hit and bind...Make sure you mark your hole as far forward as you can...Take your time and double check the placement before you cut anything..
RangerRob
Ramona, CA
You are correct, Sir. The up fitters for the F250 are the same. The part number I found for the panel is AL3Z-13D730-AA. There are a few on ebay for $75. Found it somewhere else cheaper though.
Thanks for the schematic.
-Rob
wiz1500
Sorry about the delay but I had to wait for my tools and books to come back from the west coast..
This is the connector pin location..
This is all you need to put in a set of factory uppfitter switches..If I can be more help please let me know..
