DRL/Running light tap??
kpecks
Florida
Getting ready to install some rigid radiance ditch lights and trying to find a good place to tap DRLs so the ambers come on when the DRLs are on. I need to keep all upfitter switches open otherwise I’d use two for these lights. Any suggestions? Is this harness the lighting harness??
FordTechOne
Detroit
The DRLs are powered by a module (BCM) via a transistor; it measures current draw. Adding a load to the headlamp/DRL circuit can cause DTCs to set and disable the circuit, which means no headlights.
kpecks
kpecks
Florida
I was able to find a vendor who suggested tapping into the side marker in the passenger fender. 4 screws hold the liner in place. Unscrew those, pry the plastic mounts the wires are attached to from the frame, disconnect the wiring plug from the sidemarker, tap into the blue/gray wire of the side marker harness and off you go. Works perfectly with no errors or issues. I would use a watertight connection in that area.
https://www.fordraptorforum.com/threads/rigid-radiance-backlight-question.80948/post-1579396
CACRaptor
Katy, TX
What he said.
I set a BCM DTC putting reverse lights in. The fuses don’t blow first, the module sets a fault.
There’s a very robust discussion of similar strategy; tapping high beams to trigger a relay >> off road lights. Those threads are worth a read before adding any significant load in the vehicle harness.
FordTechOne
Detroit
I would still be sure to check for DTCs after installation. The BCM will set DTCs for an out of range value before disabling the output, and there will be no visual indicator or warning messages. If the DTC continues to set after a predetermined number of cycles, the module will need to be replaced.
kpecks
kpecks
Florida
I’m just using the tap for the back lighting of the radiance lights which pulls literally next to nothing. The actual lights will be on aux 2 switch.
Antho
Hes just giving you valid information. Do what you will with “literally next to nothing” but if it knocks out all of your parking lights, you’ll know the issue.
jarhead66
florida
This is what i did when I installed my Rough country fog lights i used the yellow pass through wire and connected to the second from the right top pin this the plug by thd inside passenger panel
