No write button on line 726-87-01 see picture attached.View attachment 454454
Yes you can, but I prefer to write as little as needed being paranoid and all.Can’t you also use Write All at the bottom?
The dashs in the last two positions are for check-sum and will change when you make a change to any of the other positions.Oh. Great! My other question is about the dash hyphen, I understand that X means not changes to the current digits how about a dash?
Exactly. We started using the dash to represent the checksum. We used to just put a x there but people started noticing the values there were changing and would try to change them back thinking they did something wrong. So basically just ignore the last 2 values.The dashs in the last two positions are for check-sum and will change when you make a change to any of the other positions.
If you have not done so, print and read this....
FORScan Tutorial
Updated 2/10/25 - Livnitup What is FORScan? FORScan is software used in conjunction with a specific type of OBDII adapter that enables you to make changes to your truck's default modules' settings. Some popular things that can be changed are: adding heated and/or cooled seat icons & heated stee...docs.google.com
Thank you!The dashs in the last two positions are for check-sum and will change when you make a change to any of the other positions.
FORScan Tutorial
