FORScan and DRL
RaptorFun
Northeast Wisconsin
To date…the the values listed in the spreadsheet will not work on a MY24. I purchased and installed the harness from 4Dtech to disable this feature. Works great. Highly recommend!
RaptorAU
Alabama
Thought I’d just bump this thread. Does the DRL brightness increase work on the 24’s or no?
roadblocked
mi
I’m here for this too.
I also am wondering if there is a way to make it so the DRLs stay on until a little darker out than stock before the headlights come on
darkryder
Santa Clara
Hey @hamster
There has been some BCM changes so it took a little while to get this one figure out but this is what i had to enable. See below.
I was able to get marker/grille lights to come on with DRL in auto mode yesterday using Forscan on my 24. However, the bottom two codes made the fog lights turn on constantly and the switch would not allow for toggling on/off. Is there a way to make the fogs selectable in auto lights mode or is that not possible? At night, the fogs can be turned on/off at will, of course. Just not during the day in auto mode
Note: I might have answered my own question. If there's no way to toggle the fog lights in auto-mode, I might just order the necessary connector(s) from Specialty Performance Parts like Hamster did.
hamster
hamster
Northern VA
I searched and seardhed and played with a few things I found....I could not find a way to allow the fog switch to be able to toggle the fogs on and off in auto mode except at night once headlights on. May be a way, but I gave up. Hence why I moved the fogs up to Aux switch. Glad I did and I then connected Fogs with backlight on an S8 to use one switch.
