2022 - Error Codes and Service Required after typical ForeScan Changes.. Now something feels off once default values restored
Update - Truck back to normal, going to back back in and slowly make the desired changes using the AS-Built editor rather than the Forescan readable list.
Thanks @Nex
one change at a time
Not messing with DRL mods anymore
I still can’t believe we have a n00b FRF who actually not only took FORSCAN module backups, used the search engine AND restored from FORSCAN backups...
I feel like we’re living in a twilight zone episode...
landoawd
Chapel Hill, NC
I have zero posts to this point, but like OP, I've probably read all the cautionary tales around using Forscan so I don't need to post. Went through that thread thrice and backed up each config.
This board is a fantastic resource.
OrlandoOrangePeel
orlando
Everything is good to go, tested and re-implemented the desired changes a bit slower (one write a time again). I think there’s an issue when using ForeScans readable files… sticking to changing the as-built seems to have solved the problem.
Thanks for the help guys!
