So I just wanted to post this to see if anyone has run into this issue.
When I was replacing the seals out of the rear shock bearing housing, I noticed that the diameter of the new / replacement flat washer was bigger than what came out of the housing. I attempted to install but it is just way to big. I noticed that the flat washers that come in the front shock rebuild kits are the same size that I removed from the rear housing but the flat washers that actually come in the rear rebuild kits are too large to run.
I dont suppose that there would be any negative downsides to just throwing the old one back in there but does anyone know whats up with this?
