DIY - Stock Raptor 2.5 Shock Rebuild.
m3dragon
m3dragon
Orangevale
Finlay had a chance to rebuild the 3.0 DSC shocks. Nothing to crazy in regards to rebuild.
Also the DSC side is a pretty trick setup as you will see in the image.
I also while it was apart did a little "custom" finish to protect the remote unit. I think it came out kind of cool HAHA.
t_j
Chicago, IL
Just did a set of Icon 3.0 with CDC last night and the insides look very similar.
t_j
Chicago, IL
So I actually picked up the fox safety needle its a spring loaded self retracting needle assembly.
Safety lockout button
Needle extended
Retracting and lockout
https://vimeo.com/201489513
So one major difference is with needle, instead of having the gas opening at the end it is on the side and the point is a nice smooth point. This will help a lot as the needle will not remove a core of the rubber plug when it's inserted meaning that new plugs should be need much more infrequently.
m3dragon
m3dragon
Orangevale
AHAHAHA. Well OK then.
We just use the gauge and set it at the tank with a ball valve lever. Cheaper than your option and you can turn it on and off LOL.
McGrath4u
Needle extended
Is this the short or long needle version?
