DIY - Stock Raptor 2.5 Shock Rebuild.
Deletedone
nunya, ca
I would also recommend doing away with the needle valve inserts! I'm going to schraders, they are a pain in the ass and they lose pressure when you remove them. The other tool I would recommend is a no loss chuck with a gauge so that you can make sure you are getting the right pressure. ImageUploadedByTapatalk1454954751.846078.jpg
m3dragon
m3dragon
Orangevale
3.0's all come with schraders on rear I believe. Stock raptor shocks in the rear you can have them installed as well. Just need a conversion kit.
Fronts you need to double check if they will work. I have not tested but looking at them they may not work for front as suspension articulation will WACK it off. 3.0's the charge port is a schrader on the bypass unit.
If you make it work for fronts let me know.
m3dragon
m3dragon
Orangevale
Let me know if your bleeder screws are stuck. I like to know if it is just a stock raptor shock thing or a all shock thing.
Deletedone
nunya, ca
On my rears, 2/2 on one side were stuck and 1/2 on the other. On the front 1/2 on each shock was stuck.
m3dragon
m3dragon
Orangevale
So someone did try a install front then. Wonder if he has done a run in it yet to confirm clearing?
HAP
NE NC
JROCK what gauge and chuck is that? Is it from a kit?
Thanks,
HAP
cups
Fair Oaks, CA U.S.S.A.
I would also recommend doing away with the needle valve inserts! I'm going to schraders, they are a pain in the ass and they lose pressure when you remove them. The other tool I would recommend is a no loss chuck with a gauge so that you can make sure you are getting the right pressure. View attachment 73717
Ok since we're running two threads on this: is there enough room to use this tool without removing the shock?
