DIY - Stock Raptor 2.5 Shock Rebuild.
m3dragon
m3dragon
Orangevale
Ok after doing my due diligence the cheapest rebuild kit it from Shockseals.com.
Kris's kit has the best seals for all 4 shocks and for the best price. Only thing he does not include is the rubber pellet. That is a hit or miss if you can't re-use it. Just make sure to keep your needle safe.
m3dragon
m3dragon
Orangevale
There is no difference, both we and poly use the same Fox rebuild kits.
Thanks for confirming Jason.
For reference the diy and what I use for exchange program are from shockseals.com as noted on main post.
Any kit works but if u reference pics that is the kit I use.
m3dragon
m3dragon
Orangevale
Edited eailr post.
Shockseals.com is the best and cheapest seal kit for the DIY shock raptor builder.
m3dragon
m3dragon
Orangevale
UPDATES
Rebuilt a 5.4 that had 6.2 spec shocks. It looks like later years of the 5.4 had the 6.2 A shocks.
First months of the 5.4 have the odd ball shocks and shimms.
Will update more as more are built.
Vang
UPDATES
Those were mine!! :)
The shocks are much better than before you guys did a great job... My idea of geiser springs on top perch was horrible though. My neck hurt on the drive home! I'm gonna see how mid perch is this weekend now that its sunny I can work on it.
m3dragon
m3dragon
Orangevale
The springs were designed around mid perch so you will be much happier moving them. @vanilla_gorilla runs them and he is local. You can use a set of spring compressors and slight compress the springs while they are on the truck. them move the ring down.
m3dragon
m3dragon
Orangevale
Did our first bypass shock on a set of Fox 2.5's. Amazing how much they share the same parts with Raptor Shocks.
t_j
Chicago, IL
Just rebuilt my first set of front 2.5"s it was a breeze, take your time and anyone can do it with the right tools.
