Chris Mies
Air volume?
Yes. Sorry
Air volume?
Starting this upgrade on my '19 SCREW B&O today with the sub replacement first. It appears that the sub enclosure is a bit different from previous years, in a good way. There is no hole that needs to be filled and no plastic that needs to be melted to get the sub to fit. I'm using the Pioneer TS-SW2002D2 as recommended within this thread. All I had to do was cut off a tab on the outside and the sub dropped right in and the holes even line up with the stock screws.
Cheap "B&O" Paper Sub:
Inside the stock 2019 enclosure:
The little tab that needs to be cut off:
Pioneer fits like a charm and aligns with stock holes:
can you tell a big difference with just the new sub you put in ?Starting this upgrade on my '19 SCREW B&O today with the sub replacement first. It appears that the sub enclosure is a bit different from previous years, in a good way. There is no hole that needs to be filled and no plastic that needs to be melted to get the sub to fit. I'm using the Pioneer TS-SW2002D2 as recommended within this thread. All I had to do was cut off a tab on the outside and the sub dropped right in and the holes even line up with the stock screws.
