lawdog
- Joined
- Mar 14, 2017
- Posts
- 570
- Reaction score
- 202
Yes, I'd also be curious your impressions with just the Pioneer sub change/running it off the stock amp.
I want to make this same mod. Keep us posted. What amp are you going with?
can you tell a big difference with just the new sub you put in ?
Thanks for the info . Are you using the existing wiring or using new wires ?just curious why you couldn’t t use the original power wire from the original amp .why did you have to run a new power wire from the batteryJust finished up, definitely a huge difference. Haven't had a chance to fine tune everything with the settings on the amp or the headunit but its totally worth the upgrade. Even with the headunit EQ settings at default, there is way more bass. The biggest pain was fishing the power line for the amp from the battery through the firewall.
....The biggest pain was fishing the power line for the amp from the battery through the firewall.
Where did you go through? Driver's side grommet?
