DIY stereo upgrade for under $500.00
lateralis
Oregon
For mine 15ft got me into the bed of the truck while running the lines under the cab. So 20 ft will leave you more than enough wiggle room. Just make sure to cut it after you have run the lines and have the amp rack in place. Last thing you want to do is accidentally cut it short.
Swimmer
Olympia, WA
Does anyone know if the Pioneer TS-A6990F would be similar sounding to the TS-A6986R? I have the 2017 Sony system. Thanks.
I don’t have direct experience with both, but coax are going to produce a pretty similar sound profile. components would be a better sound stage option. These will certainly be better than the stock components.
greatone99
ma
guys on the pac speaker interface there is a male and female connector the female I assume goes to the speaker harness pulled out of the b and o amp does the male go to the female connector from the zen harness ? im assuming its the can hi and low passing thru the pac and onto the zen ?
