- Joined
- Dec 16, 2016
- Posts
- 18,029
- Reaction score
- 28,101
wouldn’t hurt to have it’s own thread - but he’s in capable hands...
I've done the Kicker and the holes line up exactly with the holes on the 2017 box. I don't know about the 2018 or 2019 trucks.
I also found this from a previous post of mine about adding a sub - "The Kicker sub holes do in fact line up perfectly. Because of the increased depth of the mounting holes, you do need new screws. I used #12 x 1 inch sheet metal screws and they worked perfectly. I did have to grind the head down a little to get them to fit the holes in the subwoofer. Also, I choose hex head SLOTTED so that I would have something to get them screwed down because the subwoofer won't allow the nut driver to get down far enough.
Also, I found it better to heat the box with a heat gun from the outside and push from the inside. Takes longer but less likely to push through in my opinion."
I've been following this thread for a while. Got a question. Looking to get this setup going
- navtv Zen a2b DSP
- Polk audio db692 6x9
- Polk audio db6502
- Rockford Fosgate R1T-S for front pillar
- Kicker 44ksc3504 for the center
- JBL exceleron xrw804 sub (worried about fit in the original location)
- JBL gtr104 amp
Maybe one of the guys here can look at this see if this will work or am I missing anything.
Help would be greatly appreciated.
Appreciate the fast response bud!- navtv Zen a2b DSP- good
- Polk audio db692 6x9- get rid of this. You don’t want Coax and a tweeter as the front stage. Get a good set of components. Put the midbass in the door and tweeter in the a-pillar.
- Polk audio db6502- fine for the rears.
- Rockford Fosgate R1T-S for front pillar- You don’t want Coax and a tweeter as the front stage. Get a good set of components. Put the midbass in the door and tweeter in the a-pillar.
- Kicker 44ksc3504 for the center- get rid of this, center channel won’t be retained. It’s also not needed anymore. The oem center channel is not a real center, it’s a mix of left and right and is only present to make up for the low power output of the factory b&o amp.
- JBL exceleron xrw804 sub (worried about fit in the original location)- can’t find this sub online.
- JBL gtr104 amp- this is only a 4 channel. If you want a sub as well, you will either need a second amp or go with a 5 channel.
- I would strongly consider you invest an additional $150.00 in a Dayton 408 DSP. It greatly improve the performance imaging of your system.
So I ended up doing this. Ran the pioneer speakers, and did the kicker cxa 400.1 (300 rms at 2 ohm) amp this amp has hi level inputs build it do it was really easy to install and do a clean job, and used the kicker compRT sub (1 ohm DVC). I also
did run a remote gain control as I listen to several different types of music. So far sounds quite a bit better than stock, (not as good as my AMG merc, but similar to my wife’s XC90 with the B&W system) and I’m sure it will get better as it breaks in.
Suggestions of what to go for vs coax?
Also the sub is Kenwood Excelon xr-w804.
