DIY stereo upgrade for under $500.00
NMSports
Had a rattle in the door, so I began the <$500 upgrade with front speakers only. Seeing the low quality of the "B&O" speakers I quickly transitioned to a full speaker replacement. Here are pictures of the stock speakers- I couldn't find pics any before I started upgrade. Paper junk. The new Pioneers weigh 2lbs more (each) than the stock fronts. The stock sub magnet is barely bigger than the stock fronts. Amazing what they accomplished with these terrible speakers.
I used the Pioneer 4-ways in the front - the front doors are crossed with no high inputs. The tweeters also stick out so far they touch the door grill. In hindsight I'd probably do a 6x9 2 way or mid only.
I wouldn't bother replacing the rear doors - the stock amp pushes very little back there. Maybe 7W RMS. I used some alpine components and drilled a tweeter into the back door. Can't even the tell a difference due to low wattage.
I used a kicker 1ohm DVC 8" woofer and a JBL 500W amp. The stock sub enclosure is robust due to the molded internal bracing. I had to plug the port due to a resonance at high volume. I think the box is too small to be ported for this sub. I'm using the speaker level inputs from old sub to new amp. Kind of a pain to tune. Even with gain set low and bass set low on the eq the amp shuts down on protect over volume setting 22. But it does shake all the mirrors so good nuff.
Amp placement - I didn't like having wires exposed in the under-seat storage area (because I use that space), so I relocated the jack to the middle underseat area, and made a vertical plate for the amp in the former jack location. You need to ensure you still have space when you tilt the seat base up (the seat-back moves back when you tilt the base). I'm going to mount a bottle jack vertically next to my new amp in the future and ditch the useless stock jack (did you know it's not tall enough to get a front tire off!).
I used Kilmat vs. Dynamat just to check it out. IMO same quality, but 40% cheaper. It really improved dynamic response and road noise. I have now set speed volume compensation to low - I was running it on high. You only need moderate coverage to achieve 90% of the benefit. I did the outer and inner door panels, as well as some large flat areas on the back of the plastic door panels. I got 36 sq. ft., did all 4 doors and the sub enclosure and have about half the box leftover. I will do the roof with the leftovers.
Crutchfield prices were same as Amazon, but Crutchfield includes the Metra adaptor plugs and plates for free (and no mistake!).
lawdog
Good stuff, NMSports.
That was the first pic I've seen of the sub cone out of the enclosure...heard about the white surround...it is pretty thick and must give decent excursion for it to sound as decent as it does.
On the speakers, just want to chime in that the front 6x9s in the kickpanel do get a full-range signal, despite the tweeters coming separately off the amp/processor. Not sure from reading your post again if that's what you meant. I put JBL 3-way Stadiums in there, and wasn't sure, but they do reproduce full-range. Having said that, if I had it to do over, I would put a good pair of 6x9 components in there, as the system was clearly designed that way/with the lower units as midbass divers.
I agree with the rears...I replaced mine with JBL Stadium coaxials, and, if I had known/realized how little they were driven off the stock amp, I wouldn't have bothered. But, it may be worth it if I later decide to do more/bypass the stock amp.
I wish there was an easier fix for the sub...I am going to wrap it soon and see what that does.
evan9r
Has anyone changed the settings in FORSCAN to 7 speaker Kicker system? I did this and maybe its my imagination but the system sounds louder. Could it be that the amp is programmed to only put out a limited amount of power to the stock speakers, and full power with the Kickers?
I haven’t tried it but isn’t that the shortcut used to disable auto stop/start?
jakedog
San Diego
I wonder if there is a kind soul that might post a recap of the issues that can be pinned or something for those that don't have the several hours to read through all of the posts. Also would be awesome to see any lists of speakers/amps that others have used!
lawdog
First, what do you have? There are a few differences between the 2017 and 2018, 801a vs 802a, etc.
’18 and up b&o resists the simple amp + sub update the ’17 Sony system allowed.
