DIY Oil Change on Raptor R
Arizona Free
Arizona
I hear ya. The $50 “The Works” oil and rotation doesn’t apply to the R.
11.5 qt full synthetic. It’s not much cheaper on Amazon either, I think $155. Filter is $35-40. So you’re not really coming out ahead much by doing it yourself.
And there are no deals to be had at any dealership. They all have the same price. They do have some ‘’coupons’’ but you don’t get and deal. It’s just their way of saying they can do an oil change. Plus all the coupons only go up to 6 quarts of synthetic blend oil. The R takes 11.5 full Synthetic 5-50 and that costs almost 17.00 per quart. They want 250.00 to perform ‘’The Works’’ , which includes oil service, tire rotation and basic check of the systems.
nelsonr103
Indiana
Get the maintenance plan when u buy it. I got a 10 year plan (5k) oil changes for $1500. That pays for the oil changes for cheaper than I could do it myself PLUS all the other maintenance things brakes, wiper blades, all fluids, lights...
EricM
OHIO
Idk about putting lube on wheel studs.
I've put a *light* coating of anti-seize on lugs without issue. It helps old crusty threads perform like when they were new threads, at least torque wise. Once the threads in the lugs and lug nuts get a bit used and corroded, the same ft-lbs on the wrench won't provide the same clamp load on the wheel that it did when the threads were new.
EricM
OHIO
Have you had an oil change performed under that plan yet?
