DIY Oil Change on Raptor R
ToadSmasher2K1
KC
Good Lord Toadsmasher, your dealership is expensive. My last oil change (a month ago) was ~$50. I call to make an appointment and request that my regular (Senior Tech) does the oil change for me. This makes me realize how good my dealership is.
I hear ya. The $50 “The Works” oil and rotation doesn’t apply to the R.
11.5 qt full synthetic. It’s not much cheaper on Amazon either, I think $155. Filter is $35-40. So you’re not really coming out ahead much by doing it yourself.
HAP
NE NC
Just be ready when the drain plug comes out. It will initially shoot all the way to the tire if you don't have the proper catch pan.
The filter needs one of the wrenches that accepts a rachet extension to loosen. Also, make sure you have your drain pan under the filter drain CAVITY, not the lip drain in the front underneath the filter when the seal is broken.
R,
HAP
SSWIM
You aren’t getting a $50.00 oil change on an R. Nope.
Sam
XSTNKT
Michigan
And I saw filter from the top
I am guessing this plate is for accessing it from the bottom but you can reach from the top too.
Well, it's a PITA from the bottom (laying on the ground). But removing the plate for the oil filter is "supposed to" expose the mouth of the drip pan under the filter. However, the oil NEVER flows out that way. It always runs out the back side and through a hole in the big skid plate. I swear that oil drip pan was designed by a first year engineering intern at Dearborn.
GEN3LV
Las Vegas
I paid for the Perineum maint Plan through my dealership everything is covered. Really didn't want to deal with scheduled maint or any problems that may arise with the truck.
