Definitely needs to be leveled
RPG
Orange County
Installed a set today.
We wanted to pull the shocks out to ensure fitment and getting good pictures.
This kit doesn't require you to remove the shocks from the vehicle.
---------- Post added at 08:37 PM ---------- Previous post was at 08:36 PM ----------
Change in vehicle ride height was +1.5"
BRAPPPP
San Luis Obispo, Ca
We are not changing any of the chassis pivots, lower control arms, upper control arms or steering knuckles, so geometry is not changed. It would benefit you to use our upper control arms due to the added caster, but not necessary.
---------- Post added at 10:35 AM ---------- Previous post was at 10:30 AM ----------
On Gen 1 we do not mandate an alignment when going from bottom to mid perch. This will be a similar height adjustment. "Top perch" collars for the gen 2 are also coming down the manufacturing pipeline.
You are changing the angle of the CVs which is part of the geometry no ? How do we run these trucks completely leveled without Cv issues like gen 1
dinoone
Awesome so just remove tire, spring compression tool, insert collar and instant 1.5" lift!!!
SOAKINRED
Orange County CA
Does 1.5" even level out the truck? At the least I would want it to be straight across, would really like it a hair higher in the front.
RPG what do you think?
SOAKINRED
Orange County CA
1.5"
If you look at the RPG thread created specifically on this new product you will see a picture of the truck and how it sits with it installed
Yes i seen the pics, that's a friends truck, but also seen pics and it looks pitched forward a little too. I asked him for a pic of it sitting on flat ground.
96,364
60,273
NTXRaptor
Latest posts
