Dunerking
Thanks for the helpful info! Like you mentioned I’ll probably stick to finding stock lower and upper control arms(unless I find a nice set of uppers used) and go with the Gen 2 shocks with corrected upper buckets from Camburg. Thanks again!
Not sure ADD is still making the kits? Or at least advertising them. Not sure if the kit was good or bad but they disappeared pretty quick. For a daily I would stay away from heims. If you were buying an off the shelf kit I'd go with Dirt Kings rubber bushing setup. It's basically Raptor width and travel numbers but you don't have to mess with coil buckets or run one oem shock vs another and you get 12" in the front. It's also setup for a bypass depending on what you want to do. Personally, and from the sounds of what you're trying to do, I'd go with OEM parts and use GEN1 shocks for a bolt and go situation or go with the KHC buckets GEN2 shocks.
Addictive Desert Designs Releases All New 2015 Ford F-150 Front Suspension Kit
Addictive Desert Designs, an industry leader in design and innovation is proud to bring the first 2015 Ford F-150 Front Suspension Kit to market. After several months of research and development with experience from the top people in the racing industry, they have built an all new suspension kit...www.addictivedesertdesigns.com
Long Travel Kit
The Dirt King Fabrication Ford F-150 long travel kit was developed to drastically improve the vehicles off-road handling without compromising its day to day driving characteristics. This suspension system allows for 12” of travel and accepts up to a 37” tire. The kit is compatible with 2WD...dirtking.com
