Deaver/eibach combo ?
Badgertits
Ma
Thanks. I'm surprised that you don't have more rake. If the Eibachs raise the front by 1.7" and the +3HDs raise the back by 2", I'd expect factory rake plus a bit, so around 2". More if unloaded +3HDs raise the back more than +3s.
I’m not surprised, EVERY truck I see running just front springs Whether geiser or eibach to “level” the truck are not level- they’re all slightly nose high lol!
reason I never installed mine, a lot of additional $$ in labor/parts to get the right stance/ride having to add the deaver springs + need to do something for bump stops, then thought to decide what type of deavers to go with & lastly- while I’d definitely coat the hell outta them w/ amsoil HDMP- seems like they’re also very prone to rusting up good
also not sure it makes sense to have the linear eibachs up front despite the cost savings...going to either install or sell em soon
K223
Florida
My truck and most I have seen are level with Eibach’s installed. The Raptors suspension is something of a self leveling system. Go park or drive on uneven ground and look how a wheel or two will have suspension extended and other wheels will be more tucked up. If you not parking this truck on level ground or the street, the front can appear nose high. Especially since, compared to stock the Eibach’s are a stiffer spring and won’t relax as easy as the stockers. This has been my observations and the characteristics of this truck and different springs.
TravisHTX
Houston
Your right, the cost is probably not worth it to most, as most probably do not really push the limits of their Raptors often enough to justify the cost. For me, besides the cost of the springs and bumpstop kit, it only cost me a $150 alignment as I did the install of the springs myself. I will have to get back to you on the rusting part, I did coat them with a couple coats of CRC Marine Corrosion Inhibitor prior to install.
The Eibachs are stiffer than stock by a little bit, so while they are less expensive than Geisers, I would not call them the "cheap" route for spring replacement. I have found I am much less likely to bottom out or rub the front skid plate with Eibach springs than with the stock springs.
Socalbeachbum
Socalbeachbum
Huntington Beach
I had the same thought until I started offroading and then I was hooked. I got my raptor for a reason.
