Gen2 stuff - EClik, Deavers, BD fogs and reverse, ARB compressor
T
TravisHTX
Houston
Price update on what’s left:
Eclik system: $1100 - Sold
Deaver +2 SD: $1000
Baja Designs fog light kit: $800 - Sold
Baja rear lights: $150 - Sold
Built right bed panels: $150 - Sold
Edited, updating which items sold.
T
TravisHTX
Houston
Update, just the +2 SD Deavers left from the original post. Still asking $1000 for those.
I forgot I had these, but I have a full set of solenoids for the 19-20 live valve shocks. They are dirty, but work fine. Asking $200 for all 4.
T
TravisHTX
Houston
No problem, thanks for the purchase! If you use the wiring that I included in the box:
For the front lights, from the upfitter switch wiring, I ran it forward along the fender, there is a hole beside the radiator that I ran the wires down to. From there, for the wires that need to go to the other side, I ran them behind the front of the skid plate. Obviously you will need a new butt connector to connect to the upfitter wiring.
The ring terminal I used one of the bolts that a ground wire was connected to the fender. I recommend a little antisieze or something on the bolt when you remove it so it doesn’t gal the aluminum as bad. And don’t over tighten! After a few times of removing/tightening those bolts for ground, I ended up having to tap new holes to ground to.
For the rear lights, I ran down the firewall to one of the body bolt brackets, then into the frame rail. To get through to the other side, I believe I ran it through the trailer hitch tubing.
