Corrosion on Rear FOX shocks AARRGH....
Cleave
Oxnard, Ca
Anything heavier duty than a paint clear coat, I don't know what would work best due to the need for heat dissipation, but maybe a ceramic coating or something could work
Cleave
Oxnard, Ca
Line-x, 5 or 6 layers of clear coat, if anyone has a better idea of a coating that would work, input would be appreciated
---------- Post added at 06:34 PM ---------- Previous post was at 06:33 PM ----------
I don't think you would be able to heat the shock to have anything like that properly adhere.
Lol, forgot you have to bake ceramic coating, sorry
NickPic83
Rockland County NY
anyone with new shocks i would suggest trying clear plastidip
im gonna try to get mine looking as good as possible and go with clear plastidip just to keep them from getting any worse
Macman
Halifax, NS
I figure I will try this new sealant and May try the plastidip route as well. Easy to remove if it doesn't work out.
ICONRep
Riverside, CA
Random question is the corrosion starting because of rock chipping? We released the ICON Midflap System a while back and it really helps stop a lot of debris from getting back to them. Might be something to consider as well. The rear shocks def take a beating with them mounted right there.
ICON Vehicle Dynamics
www.iconvehicledynamics.com
Cleave
Oxnard, Ca
I don't think it's solely caused by road salt or rock chipping, as ihavegas has the same problem on his front shocks where the perch ring sits
Macman
Halifax, NS
It doesn't appear to be from rock chips on mine, just random winter corrosion and they were coated in amsoil and I constantly washed the undercarriage over the winter to prevent the road grime from sitting on it.
ICONRep
Riverside, CA
Got it. Trust me being a shock manufacturer we deal with "corrosion" often and it is a pain in the A.
Not a lot that can be done. We have considered making some stainless steel bodies!!
