Cam Phaser/Engine Failure Reports
Status
Not open for further replies.
04Ram2500Hemi
It's Just a Username
Western Montana
2020's have a redesigned part so failures should be minimal to none.
So do all 2019's. The updated part number was implemented in production in July of 2018 on all F-150 3.5 GTDIs.
Thank you for the responses. With less than 1,400 miles I’m still learning a lot about these trucks.
K223
Florida
You want the dealer to pull the cab. The work is easier to get at and you will get a cleaned job. My guys pull cab in 30 min
Probably a lot better than someone spending hours hanging over your fenders or front end. Even with covers, things could happen.
It does seem pretty drastic for the lay person to see there truck literally separated in half.
RMB_Ryan
Wayne, NJ
I could see that. The trucks are designed by ford to pull cab. Few things Unclip, master has two nuts that get removed, and that’s it with 8 body mount fasteners
ReRun
Arkansas
Mine was built in July of 18. Dropping it off tomorrow to have them replaced and hopefully all will go well.
it’s also recently started some kind of little rattle when giving it throttle. Sounds like the wastegates or a heat shield loose or something.
loupuleff
US
I have noticed a slight roughness at idle from time to time is this one of the possible side effects ?
Sent from my SM-T813 using Tapatalk
Status
