Torque Specifications front
Description..............................................................Nm... lb-ft.... lb-in
Brake caliper anchor plate bolts ..................................250 ..184 ......—
Brake caliper flow bolt ...............................................40 ....30 .......—
Brake caliper guide pin bolt .........................................37 ....27........—
Brake disc shield bolts ...............................................18......— .....159
Brake flexible hose bracket-to-frame bolt ......................17 .....— .....150
Brake flexible hose bracket-to-wheel knuckle bolt ...........30..... 22 .....—
Brake tube fitting .....................................................17.... —...... 150
Torque Specifications Rear
Description............................................ Nm..... lb-ft.... lb-in
Axle vent valve...................................... 18....... —....... 159
Brake caliper bleeder screw...................... 20....... —....... 177
Brake caliper flow bolt............................. 40 .......30........ —
Brake caliper guide pin bolt....................... 30....... 22........ —
Brake caliper support bracket bolts............ 165..... 122........—
Brake flexible hose bracket-to-axle bolt...... 30........ 22........ —
Brake flexible hose bracket-to-frame bolt.... 17........ —....... 150
Brake noise damper..................................14........ — .......124
Brake tube fitting.................................... 17........ —....... 150
