Brake Upgrade
paj1978
So has anyone thought or gone down the path of a master cylinder upgrade like that of Wilwood or something..
MTF
Celebration, Florida
I'm not sure a Master Cylinder upgrade is worth it. IMO
But 15" front rotors (13.1" stock) and bigger calipers and stainless steel braided brakes lines certainly are.
(note: 15' rotors require 20" rims)
I see you did a little brake tweak there, what else did you do other than get fancy looking rotors.
I'm not being sarcastic!
I'm trying to understand your reason for a Master cylinder upgrade.
paj1978
paj1978
Hey Man,
Sorry for not getting back to you sooner......
I have the EBC rotors and pads with SS lines and Motul 600 fluid. not really giving me what I ever wanted from a performance braking solution...
Was looking at the master cylinder for a couple of reasons, 1. there were a few guys at TRR that had brake fluid spilling all over the place in the engine bay (plastic = shit) and 2 would you get any better clamping force with upgrading these....
But now I have gone in a very different and monster direction to fix the problem anyway....
Baer 6R in the front and 4T in the back.. all under a 17" wheel.... Booooo Yaaaa
MTF
The stock wheel? Or aftermarket wheel?
And give us updates!!!! And of course pics when you get those bad boys in!!!!!
paj1978
paj1978
It will be an aftermarket wheel. But it will be a 17" wheel..
You will also need a custom spindle/knuckle.. For the better anyway, OEM spindles suck donkey balls...
