GEN 2 Brake Rotor and Pad Replacments for 2019 Raptor.
pcs
milky way
i went with stop tech slotted/drilled rotors and motorcraft severe duty pads. good bite from those pads and the rotors allow off road debris to escape and not get caught between the pads and rotor.
thatJeepguy
GA
Why do the brakes last so long? I have 62k on the clock and ive only done the rears. Thats might be a record
For me.
Frank N
NJ and Outerbanks
My rear pads only lasted 43 k, you are not driving fast enough sir lol
I replaced everything with F-250 pads, definitely upgrade from the factory pads.
Badgertits
Ma
I rocked the OEM brakes all the way to 64k miles - still had maybe 15-20% life left but was starting to get some shimmy @ hwy speed & def noticed some fade….i went w/ power stop Z36 truck/tow kit w/ slotted/drilled rotors (honestly not usually my preference but they were on sale at the time) - the hardware is top notch, went through a New England winter w/ these on & they still look new, the stainless steel backing to the pads is visible through the caliper & is a nice touch & again- still looks new.
I didn’t need them…but for the price (I think maybe $200 or so) you can get front calipers w/ the kit & I think have option for black/silver/red color
Alcon makes a BBK that has been around for a bit but seems very pricey & requires some modding
Willwood recently came out w/ a BBK that’s more reasonably priced & bolts right on…if I was looking for more stopping power I’d consider those for the front anyhow
jimmyjamm
Bend, OR
I replaced my 3018 brakes with EBC pads and rotors and SS brake lines.
I use the slotted rotors, they make handle slots and v slots styles, same performance, just slightly different look.
Pads, go with either the Yellow (I did), or the new reds are slightly better (friend did the reds).
mashtastic
las vegas nv
I also went with power stop Z36 truck/tow kit, slotted/drilled rotors (on sale at a-zon right now). Changed out the fluid with 5.1 and have friend who made steel braided line all the way around.
¡Mucho mejor! even after 15k
scpete24
SoCal
I went power stop as well, came with new bushings and everything needed to get all the wearable components replaced except the calipers. If I need to do it again would not hesitate going with power stop Z36 again
pcs
milky way
im eye balling the wilwood kit that clears 17” wheels. im not interested in having to run 20s to clear the brakes
Winchester30
WI
OEM part #’s - I just did this in August.
Tasca Ford probably has better prices.
OEM brakes are good if you realize this is an off road truck and not a track car.
Kahuna
THE MORE YOU PLAY WITH IT, THE BIGGER IT GETS
Warning to others, I just bought the FL3Z*2200*D AND FL3Z*2C026*E from the post before mine in a rush and they do not fit my 2019 Raptor. FML
