bigger tires
malo
I have a 2023 Raptor R.
does anyone know if 38X13.5R20 tires will fit if i do the BDI leveling kit (1.25"?). and the wheel offset would be +12.
also, any guesses how far they woould stick out, if it even fits? thanks
TheButcher
I would think there is a good chance they will fit, but wheel width will need to be around 9" or less. Also depends on how you use the truck. Might have to trim a touch for clearance for regular street driving. Hard, full-cycle of the suspension might get up into the fenders a bit, but I know at least one guy on here is running a 39" BFG (so closer to 38") with about 2" front lift and it seems to work fine.
HighwaySentinel
︻デ┳═ー - - - - - - -
California
First things first. What is the leveling kit you are going to use? My quick Google search came up empty on a BDI 1.25 leveling kit.
And your difference in offset from stock will push the wheels out 7/8"
