Looking at new tires
Jafo2317
TX
I am going to be ditching the OEM 35" KO2's after having 3 of them replaced under warranty for being out of round, and starting to have the same problem again 8,000 miles later. I am looking at Nitto Ridge Grappler's, Toyo Open Country R/T Trails, and Falken Wildpeak AT4W's. which on of these should I seriously consider? I have had Ridge Grapplers 2 times before on different vehicles, and they were great, but am open to new ideas. Also the RG's are heavy. I also need good wet pavement performance along with light offroad performance. On that same note, do I stick with the OEM size of 315/70R17, or go to 35x12.5? I like that the 315/70 Toyo's can be had in d load rating, but not sure how much of a difference that would actually make. Thank you for any input you can give, because I am tired of the constant KO2 vibration.
Get the new KO3, a true 35. They look and perform great.
tm965
NOVA
just saw some advertisements for the new nitto terra grappler G3. 3p snowflake rated and in the stock raptor 35 size its about the same weight as the FP spec K02 but is e load (which i find interesting). could be a good option
