that is a really clean setup. you mounted them just above the tow hooks? I'm assuming from the picture you did not buy a flush mount kit. I was looking for the diffused pattern with those. any comment on the light output? would it be good enough to light up a camping area behind the truck?
On top of the trailer hitch, looking on the back side there is a half cutout on both sides of the factory hitch. Drilled small holes then painted and installed. Hooked mine up to reverse lights off the round trailer plug.
They are Rigid surface mounts
Was happy with the cleaner look vs the alternatives Ive seen.
