Any pics of this installed? I want to get some backup lights, but I want something flush mount. I haven’t seen any on the stock bumper so far.
On top of the trailer hitch, looking on the back side there is a half cutout on both sides of the factory hitch. Drilled small holes then painted and installed. Hooked mine up to reverse lights off the round trailer plug.
They are Rigid surface mounts
Was happy with the cleaner look vs the alternatives Ive seen.
Are you guys tying them into Reverse or just putting on Aux switch?
As designed, the kit taps directly into the reverse lights. That said, you can wire directly to your up fitter switch as long as you run the wires up front.
Additionally, we also offer a harness that will allow you to connect the lights to your up fitter and have them kick on automatically with reverse. The harness has the proper relays and diodes as well.
How did you add those clear lens? Did you cut holes in your bumper and add those lens? Great concept! Looks very clean!
